Trunk-pop switch, positive or negative?
Old Dec 4, 2004 | 02:22 PM
91 Camaro RS's Avatar
I need to know if the trunk-pop switch is positive or negative. I'm installing a remote system to just lock and unlock the doors and pop the trunk. Thanks for any help.
Old Dec 5, 2004 | 12:14 PM
Re: Trunk-pop switch, positive or negative?
Does anyone know? I grounded the brown wire that goes to the trunk pop switch and it poped the trunk, so I used a quick connect and hooked the trunk pop wire from the box, and set the fuse to negative polarity and the trunk doesn't pop. Does anyone know how to make this work? I want to put my car back together ASAP.
Old Dec 6, 2004 | 01:45 PM
convertz's Avatar
Its a positive pulse for the trunk release on a 93-95, according to designtech
if you go to www.designtech-intl.com you can find wiring diagrams and wire color tables for most cars.
Old Dec 6, 2004 | 01:52 PM
I just figured out what the problem was. It was hooked up correctly, but the quick connect didn't penetrate all the way through the coating on the wire coming from the box.
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
autoxr166
Sep 25, 2015 04:21 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
