TPS and code P0123
Old 11-18-2014, 03:51 PM
  #16
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: TPS and code P0123
Yes it is. The point is that he had a bad hidden wire and bypassed it externally. Because it was a ground wire in the same bundle and not the signal wire, he had the opposite failure.
GaryDoug is offline
Old 11-18-2014, 04:09 PM
  #17
Black93lt1's Avatar
Ok so should I check the other grounds for the pcm to check
Black93lt1 is offline
Old 11-18-2014, 04:55 PM
  #18
Prominent Member
GaryDoug's Avatar
Let's go back to the other topic.
GaryDoug is offline
Old 11-18-2014, 07:52 PM
  #19
Not Dave's Avatar
The code hasn't come back but I broke my leg last Wednesday so won't be driving the car for a while. Again I thank you guys for the help and info.
Not Dave is offline
Old 04-09-2015, 08:52 PM
  #20
Not Dave's Avatar
Just so's ya know, my car is now code free! The last one was P1441 for the evap system but I swapped out the charcoal can for a new one and the two modules inside the engine compartment.
The TPS ground is no longer an issue as the added ground wire fixed it. I never did try to locate the bad ground, I believe it's an open wire somewhere in the rear harness under the cowl.
My leg is better, 5 months later. Still not 100% but I'm old and it takes longer.
Not Dave is offline
Old 04-09-2015, 11:48 PM
  #21
Fatdog2's Avatar
Glad you fixed the Z.It will keep you young.Hope the leg heals quickly.
Fatdog2 is offline
edman
01-22-2015 02:45 PM
A's 91 Z28
01-11-2015 10:58 AM
91Bird305
3rd Gen / L98 Engine Tech
13
08-05-2002 08:42 PM
91Bird305
08-05-2002 01:39 PM
STAYBG
07-15-2002 02:21 PM
Quick Reply: TPS and code P0123
