Tire pressure
Old Sep 25, 2004 | 09:18 PM
dabez1's Avatar
Tire pressure
What pressure are your tires at for everyday driving. Its my daily driver but i race just about everyday and was wondering if i should drop the psi since they are at 44psi.
Old Sep 25, 2004 | 10:26 PM
Kataklysm's Avatar
Re: Tire pressure
Yes drop that pressure. You have it set to the max on the tires. What size tires are they? I have 275/40/17 set at 35 psi for daily driving (recommended on door sticker) Go by the setting on the door.
Old Sep 26, 2004 | 08:31 AM
Hawk#1412's Avatar
Re: Tire pressure
Keep mine between 32-34psi, getting even wear all the way around.
Old Sep 26, 2004 | 09:04 AM
Fuels94TA's Avatar
Re: Tire pressure
ditto, also give room for when the tire heats up the pressure will raise about 2 psi. 44 psi is just to high.
Old Sep 26, 2004 | 10:29 AM
Pandamonkey's Avatar
Re: Tire pressure
Yup - right around 32 is where I keep mine.
Old Sep 26, 2004 | 10:41 AM
Re: Tire pressure
44?? Ever read the tire pressure sticker that is on the door?
Old Sep 26, 2004 | 05:32 PM
dabez1's Avatar
Re: Tire pressure
Just got new tires, cooper cobras GTH, They were set at the PSi,
Old Sep 26, 2004 | 06:15 PM
Need4Camaro's Avatar
Re: Tire pressure
Dumb question for me, but besides jabbing the living h3ll out of your tire with a knife or pinning it to death with nails, how do you take preasure out of your tire?
Old Sep 26, 2004 | 06:24 PM
BlueEyedDevil14's Avatar
Re: Tire pressure
LMAO, umm...maybe push down the pin valve?
Old Sep 26, 2004 | 06:28 PM
MysticTeal 95 V6's Avatar
Re: Tire pressure
I run 36 psi in all 4
Old Sep 26, 2004 | 06:47 PM
1984camaroz28's Avatar
Re: Tire pressure
i run 10 psi in my ET streets.....
Old Sep 26, 2004 | 06:48 PM
darthrug's Avatar
Re: Tire pressure
i'm speechless. wheres your helmet lol.
Old Sep 26, 2004 | 10:06 PM
rncotton's Avatar
Re: Tire pressure
36 PSI all around for me for driving on the street. When I go to the track, I bump the fronts up to 40 and drop the rears to 24.
Old Sep 27, 2004 | 06:11 AM
97FormulaWS-6's Avatar
Re: Tire pressure
I run 32-33 psi cold on the fronts (555 Extremes, 275/40) and 15-18 psi cold on the rears (555 DRs 275/40). The fronts wear perfectly, the rears ALWAYS wear down the center first...
Old Jul 23, 2024 | 07:43 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Re: Tire pressure
My tire size is 285x35zr18, and my tire pressure is 35.5 lbs dead nuts cold.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
