Throwing Serpentine?
Old Apr 6, 2006 | 11:39 PM
EL DIABLO's Avatar
Ok people here's my problem. I have a 99TA w/bolt ons which i recently had done. I went to 3.73s and also had the pcm programmed. Since that my car has started throwing belts. I've lost 2 already and at 30bucks a pop its getting costly. I've replaced idler and tensioner pulleys already. If you've had a similar problem give me an idea please! I just don't want to start replacing parts to find the problem.
Old Apr 6, 2006 | 11:58 PM
kingslam's Avatar
Re: Throwing Serpentine?
at higher rpms? you might need an underdeive pulley with all the mods, steeper rear and higher rpms?
Old Apr 6, 2006 | 11:59 PM
Johnny Ray's Avatar
Freebird
I would have almost be it was the tensioner pulley!?
I suggest using a straightedge on your pulleys and see if by chance one of them is mis-aligned?
Just grabbing at straws here.
Old Apr 7, 2006 | 01:48 AM
Daniel6718's Avatar
check your ac...have the same problem on my truck and it has seperate ac belt that always brakes...it is not disengauging the clutch on the ac...its a switch somewhere
daniel
Old Apr 7, 2006 | 03:49 PM
Z28SORR's Avatar
The most common cause for this is a loose pully. While running check if any of them or the excessories wobble, particularly the crank pully.
Old Apr 7, 2006 | 07:08 PM
Dave89IROC's Avatar
agreed, I've replaced a few on vettes
Old Apr 8, 2006 | 12:59 AM
EL DIABLO's Avatar
Thanks for all the tips people. Especially using a straight edge "good idea". I'll be working on the car this weekend and post what i come up with. Thanks again for the ideas!
Ericksd
Jan 20, 2016 06:07 PM
PopoFormula
Oct 12, 2015 04:19 PM
zk06
Sep 9, 2015 11:39 AM
Cbr02
Aug 23, 2015 10:55 PM
whitehooptie
Aug 10, 2015 07:02 AM
