Throwing P1406 code
Throwing P1406 code
I had my SES light go on while driving and stopped into Autozone to get it scanned. The code was a P1406 which said "Auxilary emissions controls" I figured it was the EGR. The car runs great...actually maybe better.
I got it erased. I did a search on here but doesn't tell me much. I learned the code is an EGR Valve Pintle Position Circuit. I am lost as to what that means? The EGR is somewhere on one of the exhaust manifolds I was told. What should I do?
Re: Throwing P1406 code
Originally Posted by Kataklysm
Hes driving a V6 so its different. Buy a chiltons manual, its pretty good.
You sure thats the correct code?? P0401-P0405 are the EGR error codes. The Exhaust Gas Recirculation valve is located, I believe, pretty close to the firewall on the exhaust manifold. The Linear EGR is comprised of four apprx 1-2in tall black plastic pieces that are in a tight cluster. Hope that helps a bit...
The Chilton's manual code table for the 97 3.8L V6 does not show a code P1406. Only thing close would be a P1404 for an EGR pintle problem.
The code lookup CD for my Actron scanner shows a P1406, with "EGR Pintle Position Circuit". That would appear to be an elctrical problem with the positioner circuit, eithr a faulty part of the EGR, or a wiring problem. The V6 EGR valves are very complex and VERY expensive.
Drtryder
Apr 22, 2015 04:17 PM
Apr 16, 2015 09:57 AM
Gtpguy
Jan 26, 2015 04:50 PM
