Taylor Wire ?
Old Apr 19, 2007 | 10:45 PM
Metlhed54's Avatar
Taylor Wire ?
I have a set of 8mm taylor wires, will they fit in the stock looms or will i need new looms and/or zip ties to make things work? thanks.
Dan
Old Apr 20, 2007 | 05:07 AM
MARKTHOMASBRAND's Avatar
Hi Dan,
The stock wires are only 7mm,I think 8mm would be too big,especially on the passenger side loom just below and in front of the alternator by the pulleys.
My 8.5mm MSD were way to big for the stock looms,I just used zip-ties.
To help with removing the old wires I cut off one end with some scissors,then you can pull them through .
The drivers side is easy,but the passenger side is tough.I managed to do mine without removing the alternator,but there's not much room down there,believe me.
I drove my front wheels up on ramps,so I could get underneath,you can do all the driver's side from underneath.
Be prepared to spend half a day on this,and your hands and forearms will be sore the next day.Driver's side takes about 40 mins,but the 4 on the passenger side will take a few hours.
Hope this helps,Mark .
Old Apr 20, 2007 | 08:38 AM
95LT1conv's Avatar
it is tight, but the 8mm WILL fit
Old Apr 20, 2007 | 09:11 AM
Terran2k's Avatar
yeah I have 8mm taylor wires and they're a tight fit, but will fit
Old Apr 20, 2007 | 09:47 AM
Looks like I should have got 8mm instead of 8.5mm,oh well,they're on there now .
Old Apr 20, 2007 | 11:19 AM
Metlhed54's Avatar
ok good info. thanks guys.
CobraEatr
Jul 24, 2004 11:37 AM
Burn_Out
Aug 18, 2002 08:49 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
