take apart the dash?
Old Mar 23, 2006 | 07:44 PM
wakebordr2006's Avatar
does anyone know how to take apart the dash or what is needed to put new guage background in 95 camaro?
Old Mar 23, 2006 | 08:02 PM
Ok4thGen's Avatar
Re: take apart the dash?
Its not really a big deal really just start unscrewing what you need to remove, first will be the two bolts under the steering wheel for the bottom cover,
your biggest problem will be popping the top peice off as its clipped down and will more then likely break.
Old Mar 23, 2006 | 09:34 PM
revtime's Avatar
The big picnic size piece is not clipped down, it uses industrial strength velcro and if your VERY careful you can get it off without breaking it.
With that said I have a new piece waiting to be installed cause I broke mine into 3 pieces while trying to pry it off.
Old Mar 24, 2006 | 05:31 AM
is the big piece you guys are talking about the piece that is the lighter grey color that goes all the way to the windshield or is it the really dark black piece in the front?
Old Mar 24, 2006 | 06:17 AM
Dave89IROC's Avatar
yes
Old Mar 24, 2006 | 06:56 AM
jtblckmaro's Avatar
It's not that bad really, just remove the pillar trim panels and work a door panel removal tool up under the dash pad. Take your time and wiggle it down the line until you feel the velcro, and pop it off. I've had mine out about 5 times now. Nervous about it breaking every time, but it hasn't yet.
That being said, I'm sure next time I go to take it out it'll shatter into a million pieces.
Old Mar 24, 2006 | 01:47 PM
scottso's Avatar
Just had mine out. The windshield side had velcro - the dash side had clips pushed down into holes in the dash (and one piece of velcro where the point is). Maybe its different in a vert?
Old Mar 24, 2006 | 03:37 PM
well for some reason, i already have a huge crack on the grey piece that goes to the windshield so maybe that will make my life easier. which way do i pull to get the front black piece out and which way for the grey piece?
Old Mar 24, 2006 | 03:45 PM
scottso's Avatar
Are you talking about the shroud around the gauge cluster as the "black piece"? If you are - I saw a couple of screws under the gray pad. Lift the gray pad up slowly and gently in the front - I went along slowly with a screwdriver to find the clips and that is where I pried it up. Errant prying will crack it for sure. Once the front is up its a no brainer.
Old Mar 24, 2006 | 05:04 PM
yeah, thats what i meant as the black piece. sorry bout that. nut anyways, thanks for the help. i'll hopefully get started on that sometime this weekend
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
