Tail lights... need help!
Old Feb 23, 2007 | 10:31 PM
RangerBound8719's Avatar
The tail lights on my 84 work when the parking lights are on, but when I push the breaks, neither side lights up. What do I need to check on first?
Also...
My reverse lights, they flash on when shifted into the reverse gear but go out after the flash.
There is a red ground wire attached to the body of the car, but the wire is not connected to any distributer/connection.
Thanks!
Old Feb 24, 2007 | 04:03 PM
Don350k's Avatar
First I would check all fuses.
Then get a wire tester and check the break switch on the Brake pedal to see if thats ok, then move on to the headlight switch maby?
also check your bulbs, but im assuming you did this alrety.
Don
Old Feb 24, 2007 | 06:21 PM
fuses: check
Bulbs: check
Think the ground I found has anything to do with it?
2QUIK6
Sep 17, 2016 02:31 PM
greenzee28
Sep 25, 2015 04:29 PM
alphaauto
Jul 26, 2015 04:40 PM
240ssLs3
Jul 13, 2015 05:06 PM
