t- tops water drains
when i drive water leaks in where the t-tops seal meets the body seal. when heavy rain ,or sits in the rain .Are there body drains for the t-tops and where are they
AFAIK, there are not any drains in a t-top car. I've owned a couple in the past and when I looked at them the only thing I ever noticed was how nice and tight the weatherstripping fit together. Maybe yours needs to be adjusted or have the seals replaced?
If you remove a little trim, it is possible to adjust the catches for the lock pins and make it seal tighter, but if the weatherstripping is bad it will not help much.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
