Swapping Engines
It's basically a bolt in. Only problem is there is no way to remove the distributor if necessary without pulling the engine.
Due to cowl clearance you will also need a low profile distributor and cap.
Carbs are for door stops.
Re'
Due to cowl clearance you will also need a low profile distributor and cap.Carbs are for door stops.
Re'
