Subframe connectors: Bolt-on or welded?
Re: Subframe connectors: Bolt-on or welded?
I would go with the bolt-on's and then weld them. This way you can get them already powder coated and you can weld them to be just as strong as the weld in ones. Just my .02
Brandon
Brandon
Originally Posted by 87DJP2001
Since it can not be a tube which is circular, Metal stock is called BOXED when it has four sides.
Now the proper terms are Boxed stock & Tube stock in ref to metal fabrication.
"This way you can get them already powder coated "
my BMR pieces came powerdercoated, as do most other brands regardless of weld in or bolt-on.
I like my BMR tubular weld-in's, and the boxed ones as well. Yes, you have to grind away the powdercoating where you are going to weld them in, but you have to do that with any SFC's if you are going to weld them.
I would never buy bolt in SFC's and ONLY bolt them in. IF you buy bolt-in's, also weld them.
Dan
Dan
I've been a fabricator for over 25 years,we've always called it "boxed/square tubing". I think it just depends on what part of the country your in.
I have the bolt-in style SFC's,but I welded them after install. I had noway to weld them at home and limited time at work,so it was easier to mount them at home and weld later. Welding is ALWAYS better.
To get back to the original question, like IROC-T said. "welding is always better.
Originally Posted by godofdragons
what about bolt ons with some jb weld? id go pretty far to avoid taking my car to a shop
Just save your money before going that route.
Put me down for weld-in squared tube/boxed SFCs. Mine's been in for 5 years with no signs of weakening.
Originally Posted by Grave
Does anybody have any pics of SFC's installed on their cars?
