Subframe connectors: Bolt-on or welded?
Old Sep 28, 2004 | 05:56 AM
Grave's Avatar
Is there any advantages of having one over the other?
Old Sep 28, 2004 | 06:15 AM
teke184's Avatar
Re: Subframe connectors: Bolt-on or welded?
bolt ons you can install in you garage with minimal tools
weld on are more solid and rigid. after time bolt holes can elongate due to movement and allow more movement. welded sfc prevent this from happening and stiffen the car more, and stay that way over time. weld ons are typically cheaper, however you have to (most people) pay to have them installled.
call around shops, i had mine welded on very cheap cause i had a hook up, but typically $100 is a good price, as long as you do the prep work yourself. you'll have to clean off any undercoating and dirt, and probably grind off some of the paint/powdercoat from the sfc to get a goood weld. that way the shop just has to hold them up and weld.
i have alot of install and final product shots on page 3 of my webpage in the sig.
Old Sep 28, 2004 | 06:59 AM
Kataklysm's Avatar
Another vote for weld ons.
Old Sep 28, 2004 | 07:07 AM
malducato1's Avatar
go with the weld in's well worth the money, i had both night & day difference.
Old Sep 28, 2004 | 07:08 AM
87DJP2001's Avatar
Welded SFC's are the only way to go. What do you think is more solid, a bolted or welded connection????
Old Sep 28, 2004 | 11:39 AM
BirchMan98z's Avatar
You'd have to be making some pretty massive HP to stretch tubular steel, or even the bolt holes. Welds can break, bolts can be replaced much more easily.
Old Sep 28, 2004 | 11:55 AM
CscottsSS's Avatar
i'll have to disagree with that
Old Sep 28, 2004 | 01:56 PM
teke184's Avatar
it's not something that happens overnite.
bolt holes can elongate over several years, from the constant flex.
i've seen it happen on much less load bearing things than a car underbody from constant minor movements
remember, it's not the flanges of the SFC that elongate, it's usually the softer, thinner sheetmetal of the unibody.
Old Sep 28, 2004 | 02:21 PM
Rifleman_btx's Avatar
weld it, you not doing much of anything with the bolt-ons. You will be depending on the strenght of the bolt (and the bolt holes that may distort over time due to the stress) rather than the strenght of the steel. If you have bolt-ons I'd go head and have the tie-down points welded in place. Atleast then you would be geting something out of your investment. It's just my way of thinking, but I think it would be worth doing. I had mine custom made out of 1/8 inch thick square tubing. That baby is solid as a rock!
Old Sep 30, 2004 | 04:09 AM
transambill's Avatar
From the several styles,versions that I've seen the bolt on ones are more beefy and usually have extra braces comming off of them.So thats what I went with and did both,bolted and then welded them in. It made the most noticable improvement in the car as far as suspension upgrades go.
Old Sep 30, 2004 | 06:32 AM
87DJP2001's Avatar
Square tubing, is that a new style???
Old Sep 30, 2004 | 06:41 AM
teke184's Avatar
Tubing : [n] conduit consisting of a long hollow object (usually cylindrical) used to hold and conduct liquids or gases
definition doesn't neccessarily require it to be cylindrical...so yeah "square tubing" is a kind
just messing
for most driving situations, standard 4poiint sfc do a sufficient job of making the unibody rigid. for more serious racing and hp it may by beneficial to go to a double diamond style (6 pt of connection). but these can cause interferance with some exhaust setups and add extra weight.
Old Sep 30, 2004 | 03:12 PM
Ok, so what else would you call a hollow tube with four sides Mr. Wizard?!?!
Old Sep 30, 2004 | 03:43 PM
sseeya's Avatar
No it's not new. Square tubing has been around for a long time.
Old Sep 30, 2004 | 04:02 PM
87DJP2001's Avatar
Since it can not be a tube which is circular, Metal stock is called BOXED when it has four sides.
Now the proper terms are Boxed stock & Tube stock in ref to metal fabrication.
