Stock Gear Ratio
Old Oct 30, 2007 | 11:53 AM
Stl94LT1's Avatar
Stock Gear Ratio
My GF bought new tires/wheels for her 95 A4 TA. I need to know the stock gar ratio to recalibrate the speedo. Is it 3.23:1?
Old Oct 30, 2007 | 11:59 AM
The PCM has two seperate entries.... one for the tire size and one for the rear axle ratio. You only have to change the entry for the tire diameter, and only if the outside diameter of the new tire is different than the outside diameter of the tire the PCM was programmed for. Affected only by the tire diameter, has nothing to do with the wheel diameter.
A4's had either a 2.73:1 (GU2) or a 3.23:1 (GU5) rear axle ratio, and you can look for the RPO code on the build tag.
Old Oct 30, 2007 | 12:01 PM
Stl94LT1's Avatar
OK, thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
