Stock Gear Ratio
The PCM has two seperate entries.... one for the tire size and one for the rear axle ratio. You only have to change the entry for the tire diameter, and only if the outside diameter of the new tire is different than the outside diameter of the tire the PCM was programmed for. Affected only by the tire diameter, has nothing to do with the wheel diameter.
A4's had either a 2.73:1 (GU2) or a 3.23:1 (GU5) rear axle ratio, and you can look for the RPO code on the build tag.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
