Sticking T/A head lights?
Old Apr 15, 2007 | 08:58 PM
zootzee's Avatar
Sometimes my head lights won't come up, I use the manual cranks under the hood. Then when I shut the car off they work. Any ideals on what's going on?
I wasn't sure where to post this, but when the lights are broken the "apperance" of the car sucks.
Thanks all.
Old Apr 16, 2007 | 02:13 PM
transAMdriv3r's Avatar
so let me get this straight, when you shut the car off they work by the switch? im thinking either yoyu need a new relay or switch.
Old Apr 16, 2007 | 04:47 PM
lethal93ta's Avatar
I dont know if yours will be the same as mine but my one motor was loose on the gear section, grab the motor and see if you can wiggle it on the bottom part, if you can use a center punch and tap over the tabs that hold it fast on there, mine were a little loose and it would make the gears bind thats what was holding mine up. just something for you to look for.
Old Apr 16, 2007 | 09:54 PM
zootzee's Avatar
not just by the switch but they just start working. Just normal.
Maybe the relay is going?
Old Apr 17, 2007 | 11:31 AM
yeah i t would almost have to be that, I would say it would be your motors if they wouldnt go up at all, but thats not the case. so it would have to be wireing issue, relays or the switch.
Old Apr 17, 2007 | 08:16 PM
zootzee's Avatar
where is the relay located and how much is a new one?
thanks
Old Apr 17, 2007 | 09:10 PM
landstuhltaylor's Avatar
shbox.com might have some information on it
Old Apr 22, 2007 | 03:48 PM
Brent94Z's Avatar
Super Moderator
Read #5 here...
http://www.bfranker.badz28.com/headl...htgearfailures
95chwagon
Feb 28, 2015 12:02 PM
Roadie
Feb 16, 2015 10:34 AM
Cam's maro
Dec 29, 2014 08:44 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
