steering columns
Old Apr 18, 2004 | 02:16 PM
limige's Avatar
steering columns
so last fall someone tried to steal my 94z, retard was a loser and couldn't get it started, too bad... if he would've everyone would have heard it due to open 3" exhaust.
anyway, i bought a column from a firebird, 4th gen, forgot what year..
i went to put it in today and it's too short!!! wtf? by 2", my old one stuck out 4" of shaft from the column, new one only has 2" sticking out!!
i thought they were all the same!
does anybody know if that shaft is two peices inside? maybe i could swith the end somehow?
this sucks, i'm thinking about machining an adaptor if i can't switch the shafts somehow..
anyone got info on columns, why did they change them at all?
thanks,
mike
Old Apr 18, 2004 | 02:22 PM
Do you mean that it is too short to reach the steering shaft connection under the hood? Maybe the column you got had been in a wreck and was collapsed (like they are supposed to do).
Old Apr 18, 2004 | 02:29 PM
limige's Avatar
yeah, it doesn't meet the steering knuckle, how could i tell if that's what happened, and can it be fixed?
btw thanks for the quick reply
Old Apr 18, 2004 | 02:55 PM
See if this helps.
Old Apr 18, 2004 | 03:06 PM
limige's Avatar
thanks i'll go check, man you are too awesome, i hope i can make a donation some time to you, you really deserve it! but for now there are bills to pay... they say what goes around comes around, i hope you get all you deserve!
ttl,
mike
Old Apr 18, 2004 | 04:17 PM
limige's Avatar
try link below
i'm having problems making heads or tails of that, what can you tell me?
Old Apr 18, 2004 | 04:20 PM
I'm not sure I know what the question is.
Old Apr 18, 2004 | 04:56 PM
limige's Avatar
i'm not sure if it's collasped, the drawings show a picture, but i'm not sure where to look! where are the plastic injection holes at?
Old Apr 18, 2004 | 05:08 PM
limige's Avatar
http://www.pbase.com/limige/inbox
sorry link was wrong try this link!
Old Apr 18, 2004 | 05:11 PM
Looks like the plastic is up on the lower shaft. I don't know if you can see them without disassembling the column.
Old Apr 18, 2004 | 05:16 PM
Mine looks like the upper one, with about 4½" from the end of the tube to the end of the shaft that bolts to the steering coupler.
Old Apr 18, 2004 | 06:32 PM
limige's Avatar
yeah the upper is my old one....
on the new one one of the pads that bolt upward into the dash is kinda loose, you can wriggle it but not pull it out, everything else seems kosher, i may have to disassemble both to make one good one.....
what a pain, if the steel shaft pushes up during a collision then that is what happened but thats the only think that doesn't add up. everything else is the same!
Old Apr 21, 2004 | 07:02 PM
limige's Avatar
shoebox
i started tearing it apart today and the end slipped further in...so i gave it a firm tug out and was able to pull it out to the correct length...
so it must have collasped.
is it ok to use now? is it on a splined slip joint shaft to extend and retract or what?
thanks,
mike
Old Apr 21, 2004 | 08:11 PM
shoebox
thanks,
mike
According to the factory service manual, it should be replaced.
IndyZman
Oct 22, 2015 02:17 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
