starting problem
Old 09-01-2014, 06:20 PM
  #16
warmeck's Avatar
Re: starting problem
Originally Posted by Injuneer
And, a faulty ICM may set codes, and the ICM can be tested, usually for free, at an auto parts store. Much cheaper than assuming you need a new one.
We've suggested numerous possible causes, but I don't see much to indicate you actually followed up and checked them out.
got the ICM tested and it came back as good, getting 41-45 on the fuel pressure test
warmeck is offline
Old 09-02-2014, 09:42 AM
  #17
Originally Posted by warmeck
...... i did index the opti correctly i did not force it on.
You would be surprised how many people have come here with the same problem you have, sworn they did the install correctly, only to find out later it was not installed correctly.
Injuneer is offline
Old 09-02-2014, 06:23 PM
  #18
warmeck's Avatar
i found out the icm tested good but was actually bad, so i replaced it and it starts up fine thanks guys!!
warmeck is offline
Alex Barnes
01-24-2015 10:21 PM
Oncomingstorm22
01-22-2015 07:15 PM
HCz28
01-11-2015 11:21 AM
97z28k&N
01-09-2015 04:58 AM
97SSdude
12-31-2014 07:43 PM
Quick Reply: starting problem
