Starting problem
Old Aug 16, 2004 | 12:04 PM
T94Z28's Avatar
Exclamation Starting problem - C'mon, help please! Ideas???
I have a '94 Z28, 5.7L, automatic. I am having trouble (intermittent) starting the car. When the ignition switch is turned, sometimes there is a delay before the starter engages, sometimes not. When there is a delay, there is no clicking (as when the battery is low). I changed the battery, starter, and even the battery connection bolts. The idiot lights come on as usual when the key is turned, and there is less current draw now (as indicated on the instrument panel voltage meter) when the key is turned than there was before changing out the starter (I thought the solenoid might be the problem). BTW, the ignition switch was changed out about a year ago, along with an engine tune up.
I've cleaned the battery connections etc. with a wire brush and relanded them.
Any other ideas??
Old Aug 18, 2004 | 05:05 PM
T94Z28's Avatar
Exclamation Re: Starting problem
I need some ideas! Anyone...
Old Aug 22, 2004 | 04:48 PM
noc_81's Avatar
Well... When my starter was about to die, I had problems starting it every once in a while. The thing wouldn't even crank. After a 10min jump from another v8 once, I got it cranked up. Other times it would start after about 15min of trying. All of a sudden, the starter took a crap in a K-Mart parking lot.
Old Aug 23, 2004 | 06:05 PM
T94Z28's Avatar
Ok, problem solved. The security system was going out, and would sometimes lock out the starter.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
