Squealing Left and Right
Old Nov 9, 2007 | 11:58 AM
93Z28rare's Avatar
Hey everyone,
My car has started to squeal very loudly when the steering wheel is being turned left or right. Bumps also seem to make it squeal. The noise is coming from the front of the car. I don't think its the power steering because it seems to work fine. Could it be the shocks?
The car is a 1994 Z28 with QA1 adjustable drag shocks and Eibach drag springs in the front. Thanks.
Carlos
PS: I already posted this on the suspension forum, but I think I can get a quicker response here. Thanks
Old Nov 9, 2007 | 06:51 PM
mrmint69's Avatar
If the power steering is bad it would make the noise while parked as you turn the wheels. Need to know exactly where the noise is. If the springs or shocks are making it, you can push on the fender and compress them to see if it does it.
Old Nov 9, 2007 | 07:59 PM
DaddySS's Avatar
Does it happen whether the car is warm or cold, moving or stopped? What does the squeal sound like, groan, high pitched? Does it continue for as long as the wheel is turned or stop when stop turning the wheel?
Old Nov 10, 2007 | 10:42 PM
capp's Avatar
i say its the power steering
it may still work fine, but if it may be a sign that the pump is starting to go out.
Old Nov 11, 2007 | 06:49 AM
RE AND CHERYL's Avatar
Might sound dumb, but is the belt slipping? I've seen tesioners go bad and not keep proper tension on the belt many times.
Re'
Old Nov 11, 2007 | 03:08 PM
93Z28rare's Avatar
It's actually more of a groan, or creak. It happens also when the car is pushed up and down and not just when the steering wheel is turned.
Carlos
Old Nov 11, 2007 | 05:32 PM
mrmint69's Avatar
My poly bushing on the rear end make the same sound your describing. You might need to lube the chassis if your using rubber bushings or grease the bushing if they have the grease fittings. Assuming the shocks or springs are the cause.
Old Nov 11, 2007 | 06:23 PM
ScottsZ's Avatar
My guess is it's either a tierod end or a balljoint.
Old Nov 12, 2007 | 06:46 PM
93Z28rare's Avatar
I just hope it is something simple. Bushings sound harder than tierod end or ball joint only because it looks like it may be the control arm bushings.
Carlos
Jeff1904
Jun 5, 2016 05:00 PM
fift5
11
Oct 1, 2015 10:31 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
