Squealing Left and Right
Hey everyone,
My car has started to squeal very loudly when the steering wheel is being turned left or right. Bumps also seem to make it squeal. The noise is coming from the front of the car. I don't think its the power steering because it seems to work fine. Could it be the shocks?
The car is a 1994 Z28 with QA1 adjustable drag shocks and Eibach drag springs in the front. Thanks.
Carlos
PS: I already posted this on the suspension forum, but I think I can get a quicker response here. Thanks
Carlos
If the power steering is bad it would make the noise while parked as you turn the wheels. Need to know exactly where the noise is. If the springs or shocks are making it, you can push on the fender and compress them to see if it does it.
Does it happen whether the car is warm or cold, moving or stopped? What does the squeal sound like, groan, high pitched? Does it continue for as long as the wheel is turned or stop when stop turning the wheel?
My poly bushing on the rear end make the same sound your describing. You might need to lube the chassis if your using rubber bushings or grease the bushing if they have the grease fittings. Assuming the shocks or springs are the cause.
