Squeaky clutch?
Old Jul 14, 2004 | 06:55 PM
slomarao's Avatar
Squeaky clutch?
I have had this problem for a long time. I have got down and oiled, wd-40,silcone,grease,etc. The parts under the dash. Nothing has worked.
When I ask about how to fix it at the local shop they tell me it is just a problem with these cars and you got to deal with it. My situation is annoying because it comes and goes. So whenever your pissed off and you get back into your car it starts.
Just wanted to know if anybody has the same problems?
Old Jul 14, 2004 | 09:08 PM
RedHottG2's Avatar
I had the same problem with my 95 Formula. I had a 93 Z28 and it never happend. I did all the same things you've done on my 95 and it always went away and came back over time. I guess your best option is to replace the pedal assembly. I never got around to doing that, but I think it would go away then.
Old Jul 17, 2004 | 11:58 AM
slomarao's Avatar
n e body else?
Old Jul 17, 2004 | 01:49 PM
Camaro4me's Avatar
Same thing in my 96' Z , I just shoot some WD 40 up near the top of the clutch assembly and it goes away for a year or two. (Alot cheeper than replaceing the clutch assembley)
Old Jul 19, 2004 | 11:25 AM
SixSpeedShifter's Avatar
Re: Squeaky clutch?
I have the same problem in my 94 bird as well. I quickly tried some WD-40 but it didn't do anything. I guess I'll give it another shot...
Old Jul 19, 2004 | 04:14 PM
slomarao's Avatar
Re: Squeaky clutch?
Somebody has fixed this before.
Old Jul 19, 2004 | 04:22 PM
coogsLS1's Avatar
Re: Squeaky clutch?
I was told it was the clutch pedal return spring but our cars have hydrolic systems so I am guessing replace the master cylinder.
Old Jul 19, 2004 | 09:54 PM
Kevin97ss's Avatar
Re: Squeaky clutch?
I spent an hour under the dash one day trying to figure it out. Here is what I found, lubing all the piviot points didnt do squat. The culprit is the starter saftey switch(black square button behind the pedal arm) its very hard to access but if you can reach it put some bearing grease on all four sides.
Kevin
Old Jul 19, 2004 | 11:59 PM
ReNxWar's Avatar
Re: Squeaky clutch?
My 95 Camaro has the same problem, I've just gotten used to it.. the music usually blocks it out.
Old Jul 20, 2004 | 10:25 AM
StreamlineZ28's Avatar
Re: Squeaky clutch?
i have a squeak like that, that comes and goes. in my car it was a wet shoe. took me a while to figure out that it only did it when my shoe was wet.
Old Jul 20, 2004 | 10:29 AM
DrewHMS97SS's Avatar
Re: Squeaky clutch?
Kevin
i will have to try that, ill be under the dash today anyway
Old Jul 21, 2004 | 08:45 PM
slomarao's Avatar
Re: Squeaky clutch?
I have been using the radio to drown it out too. I get real sick of it when it's 5:30 am and I have to blast music when I'm on the highway.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
