Speedometer Failure...
Old May 4, 2005 | 10:07 AM
Need4Camaro's Avatar
Just happened this morning...On my 97 V6... The Tach works fine, however when I'm moving the Speedo is at 0... Sometimes it will swing around but always lands back on 0... Whats the problem and how much am I looking at for a repair... Can it be done myself?
Old May 4, 2005 | 10:21 AM
wogert's Avatar
Re: Speedometer Failure...
well to start... it could be the cluster... or it could be the sensor in the transmission tailshaft... or it could be the BCM or ECM (I cant remember which one handles speedo)... or it could be a bad wire...
Without a scanner, I'm not sure how you'd diagnose it. Hopefully, someone else here will have some diagnostic suggestions, though.
Old May 4, 2005 | 10:26 AM
A scanner can check for any codes and read out the MPH if it sees pulses from the VSS. That will tell you whether the trouble is between the VSS and PCM or PCM and cluster.
Old May 4, 2005 | 10:39 AM
Eh, anyway to check without a scanner?
Old May 4, 2005 | 11:33 AM
For function of the sensor, not that I know of. If you just want to check continuity of the wiring, you can to that with a meter.
Old May 4, 2005 | 12:37 PM
If the VSS is faulty, the SES light should be on.
Old May 4, 2005 | 07:54 PM
Where's the wire at for it anyway?
Old May 5, 2005 | 09:30 AM
The VSS is on the drivers side of the tranny, on the tailshaft housing. It goes to PCM pins A31 (purple wire) and A32 (yellow wire).
Shoebox has the pinout data on his website:
http://shbox.com/1/1995_pcm_conn_a.jpg
Old May 5, 2005 | 04:25 PM
Okay, New issue... If the VSS or Speedo Sensor was faulty on an A4... They say I shouldn't beable to get out of 1st...
Here's exactly what it's doing. Hit a bump and it will fling into action then die again. When I'm doing about 70 (2.2k RPMS for my car) it says I'm doing 10 - 25 and just bounces around that area erratically until I hit a bump and it may or may not jump to about 50... but then falls again...
Could this also be a faulty gauge cluster? Because I'm shifting quite fine...
Old May 5, 2005 | 09:01 PM
ttt
Old May 5, 2005 | 11:26 PM
If it were the cluster... Would the Odometer and Tripometer malfunction aswell? Mine are but I thought it would with the speedometer inactive anyway...
Also when I bang on the dashboard the needle bounces around... That normal?
Old May 6, 2005 | 12:01 PM
Where's the VSS on the tranny? I'm looking at the tailshaft where the driveshaft meets and can't find it...
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 12, 2015 10:12 PM
red
Apr 6, 2003 08:02 PM
Michael Ozorowsky
Oct 2, 2002 01:58 PM
