speedo sticking
Old Sep 24, 2005 | 09:37 AM
TTlord's Avatar
speedo sticking
ok well i went to the t4rack last night and had an awesome time. anyhow while i was driving home i noticed that my speedo was sticking. when i am stopped it is stuck on 20 or so, and when i go it will jump between speeds. it doesnt have the fluid like movement from previous. the only way i had a good idea what my speed is from my tach. any ideas?
Old Sep 24, 2005 | 02:53 PM
TraceZ's Avatar
Re: speedo sticking
I bet the gauge went bad. Can you plug a scanner into it and see if the PCM is geting the correct speed from the VSS?
Old Sep 24, 2005 | 06:56 PM
TTlord's Avatar
Re: speedo sticking
dont have a scanner on hand. where is a place i could find one?
Old Sep 24, 2005 | 07:53 PM
TraceZ's Avatar
Re: speedo sticking
Well, I guess I made some assumptions. I have no idea what kind of car you have. You should go to usercp -> edit signature and create a signature that contains some basic info on your car like year/make/model and what mods it has on it.
I assumed you had a 4th gen with electric speedometer. If you have an older car with a cable driven speedo the problem is different.
Old Sep 24, 2005 | 10:35 PM
TTlord's Avatar
Re: speedo sticking
i will make the additions to my signature. i have a 94z28. i took it out for a ride today and it worked ok for awhile, then it started to stick again.
Old Sep 29, 2005 | 03:39 PM
TTlord's Avatar
Re: speedo sticking
ok well i drove my z yesterday and when i started it up the service engine soon light stayed on. i called the local dealer they want 85 bucks just to hook it up to a computer to see what the diagnostics is. is there a handheld i can get that will do this for me? i thought that there was something called a scanmaster. i work nights and usually its about 14hrs, so i am not around much but i have the next few days off and would like to take care of this any help would be appreciated. by theway the car only has 16,500mi.
Old Sep 30, 2005 | 06:43 PM
Z95m6's Avatar
Re: speedo sticking
You can get a scanmaster but they are $200+ but a good tool to have. If you have a laptop it might be cheaper to get a cable and scan it that way.
Old Oct 1, 2005 | 03:16 PM
Sh4Dy's Avatar
Re: speedo sticking
Take it to autozone/advanced auto they will scan it for free.
Sep 27, 2015 01:55 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
mmf_1013
Sep 12, 2015 08:56 PM
LazyLemming
Aug 29, 2015 07:36 PM
