Spark Plug Stripped
Old Aug 15, 2004 | 05:58 PM
OBDIICamaro's Avatar
Spark Plug Stripped
Ok what can you do to a aluminum head? I cant believe I did this but when putting number 5 in it somehow got crooked and screwed up the threads. I got it to line up as close as possible in comparison to the other plugs angle wise but of course it was tight going in. What are my options, can I helicoil it with the head still on or does it have to be jerked off because of shavings? Will this cause any firing issues also?
Old Aug 15, 2004 | 06:05 PM
sleeperz28's Avatar
Re: Spark Plug Stripped
You will have to ask your self these questions can you? I would pull the head
Old Aug 15, 2004 | 06:08 PM
robertg's Avatar
kd-tool makes a tap that expands and cuts from the inside-out, but i don't have any experience with it.
i'd pull the head as well.
Old Aug 15, 2004 | 06:32 PM
Lazyness kicking in.
Old Aug 15, 2004 | 10:14 PM
This is probably a good topic for "General F-Body Tech"......
Old Aug 16, 2004 | 08:57 AM
slayer6x6's Avatar
I would pull the head, the last thing you need is to finish fixing the threads and then find out that you lost compression in that cyl.
Old Aug 16, 2004 | 07:37 PM
I read a post of a guy that used that tool. Worked for him. I have seen it in a NAPA flyer. Not cheap, but if you can get to the plug hole, less work than pulling a head.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
