some guage lights on that shouldn't be...help figure this out
When the car has the e-brake on, nothing is wrong, but when I take it off and start to move, the ABS INOP light, and the ASR light come on and stay on, untill i eventually park and put the brake up. Also, sometimes (not always) if I hit a bump in the road, the BRAKE and LOW TRAC lights will flash.
I know some others have had this problem, what have you all found out? What should i look at/clean/replace?
Re: some guage lights on that shouldn't be...help figure this out
I would start by cleaning and tightening the ground lugs on the RH shock tower. You may also need to check the connections at your wheel sensors.
I fixed this problem, finally. What i did was clean the wheel sensors out. It was one of my front wheels. It took 3 driving cycles for the code to clear. During those cycles the Brake and LOW TRAC lights flashed constantly, then they finally went off about 10-15 minutes of driving the 3rd time out. They havn't come back yet
i have a similar thing happen. sometimes when i start to let the clutch out and begin to move the abs light flashes really quick and then goes off. its weird but never stays on or anything.
z95m6 - you know you might be right there cause it rarely ever happens and i have a feeling it is on starts like that. ill have to test it out. i bet ur right though. thanks.
Jul 4, 2005 05:00 PM
