some guage lights on that shouldn't be...help figure this out
Old Sep 7, 2004 | 08:58 AM
rlax31's Avatar
When the car has the e-brake on, nothing is wrong, but when I take it off and start to move, the ABS INOP light, and the ASR light come on and stay on, untill i eventually park and put the brake up. Also, sometimes (not always) if I hit a bump in the road, the BRAKE and LOW TRAC lights will flash.
I know some others have had this problem, what have you all found out? What should i look at/clean/replace?
Old Sep 7, 2004 | 09:09 AM
Re: some guage lights on that shouldn't be...help figure this out
I would start by cleaning and tightening the ground lugs on the RH shock tower. You may also need to check the connections at your wheel sensors.
Old Sep 7, 2004 | 09:25 AM
rlax31's Avatar
Fisrt on the list when I get some time
Old Sep 7, 2004 | 10:47 AM
slayer6x6's Avatar
Its normal for the low trac light to come on when hitting heavy pot holes.
Old Oct 4, 2004 | 12:42 PM
rlax31's Avatar
I fixed this problem, finally. What i did was clean the wheel sensors out. It was one of my front wheels. It took 3 driving cycles for the code to clear. During those cycles the Brake and LOW TRAC lights flashed constantly, then they finally went off about 10-15 minutes of driving the 3rd time out. They havn't come back yet
Old Oct 4, 2004 | 05:22 PM
Metlhed54's Avatar
i have a similar thing happen. sometimes when i start to let the clutch out and begin to move the abs light flashes really quick and then goes off. its weird but never stays on or anything.
Old Oct 4, 2004 | 06:30 PM
Z95m6's Avatar
Metlhed54 i'm going out on a limb here, just taking a guess. When you start out from a stop and that happens are you letting the RPM's drop a lot? by that i mean down to approx. 500. If so it might be that you are about ready to kill the car and the ABS sensor isn't getting enough juice. I had kind of a similar problem. My old fuel pump was going out and was eating up lots of juice so much juice that when i would floor it and the car got into the higher RPM's the ABS light would go off because of lack of juice. At least thats what i've come up with as it hasn't happened again since the fuel pump and it use to happen all the time.
Old Oct 4, 2004 | 07:06 PM
Metlhed54's Avatar
z95m6 - you know you might be right there cause it rarely ever happens and i have a feeling it is on starts like that. ill have to test it out. i bet ur right though. thanks.
mattstrike
Mar 24, 2015 02:11 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
smokin25th
Jan 1, 2015 09:06 AM
Jul 4, 2005 05:00 PM
Absolute Z28
Jul 19, 2002 02:21 PM
