Skip Shift Eliminator
Old Sep 19, 2009 | 10:12 AM
denverz28's Avatar
Hello,
Would someone have a garage setup, where I can install a skip shift eliminator on my '94 Z? I'd be glad to pay you.
Thanks.
Mike S.
Denver, CO
Old Sep 19, 2009 | 10:20 AM
JETMAN95Z28's Avatar
I don't havae a garage and I installed mine with no issues in my driveway. You will need to jack your car up to get under the car to get the transmission where the connections are made. It's really pretty simple from there. It's one of the VERY best mods I ever made to my Z by far. I HATE the skip shift feature!!!
Old Sep 19, 2009 | 10:22 AM
mudbone's Avatar
You are welcome to come use my shop, but I'm afraid the trip might be a bit excessive I'm in VA. FWIW, other than a jack and two jack stands, you don't really need anything else. Plus, it will only take about 30 seconds to install it. I jacked up my car sideways on two wheels, lifting the left side of the car about 18-inches. I then slid under on my creeper and made the connection. Lifting the car took the most time. If you have a jack, you can do this in a parking lot. Don't forget the jack stands!!
Old Sep 19, 2009 | 03:28 PM
Jack up the driver's side. Use jackstands. Slide under the car and unplug the harness connector from the "ship shift" solenoid. You don't even need the "skip shift eliminator". Although the OBD-I cars (94/95) set a DTC code for a non-functioning skip-shift solenoid, they do not turn on the SES light. OBD-II (96/97) does turn on the light.
Since you have the "eliminator", install it. But you could have accomplished the same thing for less than $1 by getting a 2 Kohm resistor at Radio Shack, and plugging the resistor wires into the harness connector and taping it up.
Old Sep 21, 2009 | 03:56 AM
madhatter's Avatar
http://www.bfranker.badz28.com/96SS/skipshift.htm
Free, and gets rid of the light altogether. Best way to do it on a 94-95 car.
Old Sep 27, 2009 | 07:32 PM
denverz28's Avatar
Thanks for all the great advise! It's great not getting dumped into 4th gear anymore. Where can I buy a Gen 4 Z28 baseball cap?
Mike S.
Denver, CO
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
marlar98
Sep 19, 2015 07:53 AM
