Shoulder Harness
Old Dec 5, 2004 | 11:59 PM
camaroKid223's Avatar
Shoulder Harness
Iv been seeing a couple cars around here that have 3 point (i think) harness's that use the stock seats and no rollbar. there is a strap that goes from the harness to a mount on the rear deck behind the rear seats. does anyone know what im talking about? are they safe? good for autoX maybe just not daily driving?
Old Dec 6, 2004 | 11:41 AM
Re: Shoulder Harness
You probably mean a "4-point" harness, consisting of a left and right lap belt, and left and right shoulder belts. Someone makes a cross-bar that fits in behind the seat, and allows you to bolt the shoulder straps in, or you could mount some sort of an anchor to the "package shelf", much to the consternation of any back seat passengers. I would also question the ultimate strength of an anchor through the thin sheet metal above the fuel tank.
You also might want to consider the fact that most aftermarket "harnesses", including the highest quality Simpson 6-points, are not DOT approved, and hence not legal for street use, even though though they are SFI-certified for top fuel dragsters.
Old Dec 7, 2004 | 04:55 PM
Z28SORR's Avatar
Well you can get by the illegality, by leaving your stock belts in for regular driving. Go to one of the WEB sites, like Simpson . Most have instruction on how to set these up. If you have them at the wrong angles you can do more damage to your body than good.
Old Dec 7, 2004 | 07:55 PM
do u know if you can get the right angles in a fbody without a bar?
Old Dec 8, 2004 | 12:30 PM
Z28SORR's Avatar
Yes, but in doing so you probably now have a strap that is to long. I think a harness bar is probably the minimum you need for correct installation.
If the shoulder belts are to long, attached to the shelf or layed over the harness bar and attached to the floor, there is a good chance that they will stretch to the point that your face will hit the steering wheel. if you don't have them restrained by a clip on the bar they can also slide side ways off your shoulders, particularly if you don't have a racing seat.
The belts should be at shoulder height and within a few degrees of straight back, and as short as possible. To much of a down angle will cause compression of the spine in an accident. The belts should also be restricted from moving off the shoulders, either by restaining them at the bar or running them though hole in the seats.
G-BODYT56
Jan 14, 2022 11:14 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Thirim
Jul 30, 2015 01:29 PM
RUNMYTA
Jul 15, 2015 07:50 PM
