Shifter Lock help
Old Oct 4, 2005 | 07:25 PM
crazypurgatory's Avatar
Question Shifter Lock help
I can put my car into drive without putting my foot on the brake.
What part do I need to replace?
Also I have a ABS problem would the non working ABS make this piece not work?
Thanks,
Chris G.
Old Oct 9, 2005 | 06:01 PM
Re: Shifter Lock help
TTT anybody know?
Chris G.
Old Oct 9, 2005 | 06:07 PM
The BTSI solenoid could not be receiving power or mechanically disconnected. Take the shifter cover plate off and check to see what is going on.
Old Oct 12, 2005 | 12:17 PM
Question Re: Shifter Lock help
And once again your right.
Do I have to buy this from the dealer I can't find it online at Advance auto parts or Auto zone.
The dealer wants 40 bucks for it.
If I can't find ti cheaper I will have to go to the salvage yard.
EDIT
Well I got one at the salvage yard for 5 bucks.
I still would like to know where I can buy a new one?
BTW this thing is an electro-magnent.
I don't know how that could go bad no moving parts.
I thought it was a solenoid.
Chris G.
Old Oct 12, 2005 | 04:21 PM
It may be a dealer item. A solenoid is basically an electromagnet. Based on how it is designed, it can perform different functions.
Old Oct 12, 2005 | 05:37 PM
Hay Rob
I check for power at the solenoid and found out that there was power there so I went and got a solenoid from a salvage yard.
Plug it in and nothing.
I found out that there is some up and down play in the brake pedal and if I put my foot under the pedal and push up the solenoid works but the pedal falls down a tiny bit and it brakes the connection.
Is there an "adjustment" in the brake switch that controles the solenoid?
And the solenoid works I check it off the car som now I have a spair.
Thanks,
Chris G.
Old Oct 12, 2005 | 10:31 PM
There definitely is adjustment on the pedal switch. It's easy to figure out when you look at it.
Old Oct 12, 2005 | 10:40 PM
Lightbulb Re: Shifter Lock help
Thanks Rob I will look at it in the morning.
Chris G.
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
CARiD
Sep 7, 2015 08:21 AM
