Shifter Knob?
Old Apr 6, 2007 | 12:41 PM
1994CamaroLT1's Avatar
Shifter ****?
I am currently redoing the interior in my 1994 Camaro and i am trying to get the center console out of it. Do you just twist the **** off of the shifter (i have an automatic)? Thanks
Old Apr 6, 2007 | 12:46 PM
2001NBMZ28's Avatar
Turn key on and put the shifter in 1st - there's a small "staple" clip on the front of the handle. Pry it out then it pull straight up.
Old Apr 7, 2007 | 12:37 PM
Jared 3870's Avatar
2001NBMZ28 hit it dead on, just don't mangle your shift **** whenever you are pulling the staple out.
Also, when you are taking the center console out you will have to get the emergency brake lever straight up. There are some pictures online you could search for, but it involved taking a screw driver and prying some part of the mechanism back in order to release it from the gear. I'm drawing a blank on the exact process, but search for it and you will find it, thats what I did when I removed mine.
Some say you can just yank it up but I don't think that is the proper way to do it.
Old Apr 7, 2007 | 06:18 PM
Craddock's Avatar
If you pull it fast you can just yank it up. I traded mine out and that's what I did. I did it like mentioned earlier the first time, and I regret it cause the e-brake doesn't work as well now.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
