SES light
Old Jun 21, 2004 | 03:11 AM
dabez1's Avatar
SES light
Will driving around i got the SES ligh on the dash, and now everytime i use the car the light apears about 5 minutes after startup. How can i figure out what is causing the light to come on, such as the error codes it gives out.
Old Jun 21, 2004 | 06:15 AM
What year is your LT1? From the mods list, at least it appears to be an LT1. 93 you can flash the codes on the SES light by shorting a couple of ALDL pins. On the 94 and newer models, you need a "real" scanner.... OBD-I for the 94 and 95s, OBD-II for the 96 and 97's. Some shops (e.g. AutoZone) will scan the OBD-II cars for free.
Its really important to include the year of your car, to be sure you get the right answer.
Old Jun 21, 2004 | 10:47 AM
LOW TRAC's Avatar
I had a problem similar to this about a year ago, check the fuse under the hood for the air pump. About 5 min after start up the car should be shifting into closed loop and finally listening to the O2 sensors. Just a sugestion. If I remember correctly the fuse was on the left (drivers) side of the engine bay, yellow I think.
Old Jun 21, 2004 | 05:12 PM
dabez1's Avatar
Sorry about that its a 94 a4 Trans Am. Im going to have it scaned to make sure, thanks for the help.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
