service engine soon and check engine same?
Old Mar 23, 2012 | 01:33 PM
Javi_1591's Avatar
have a 2001 z28 and service soon engine light came on is it the same as check engine light ? i heard service engine is to change oil spark plugs etc and check engine is for problems with the engine
Old Mar 23, 2012 | 02:00 PM
mrmint69's Avatar
Re: service engine soon and check engine same?
You set a code and this tells you that something is wrong. Pretty much the same thing. You can get it read, so you know what might be wrong. These are pretty basic computers, so things like oil changes are not show or basic maintenance.
Old Mar 23, 2012 | 02:50 PM
Javi_1591's Avatar
Oh but i know some cars have check engine light is it the same light just depending what kind of car that depends which light it has?
Old Mar 23, 2012 | 03:16 PM
bobdec's Avatar
On the LT1 F-Body Check engine is controled by circuits in the dash cluster it indicates low voltage or low oil pressure or high temp coolant, a signal to look at your dash gauges.. Seperate from the Service Engine Soon (SES) light that is illuminated by the PCM for engine/powertrain sensor or emission failures. I would assume the 2001 LS cars would be similiar, but I could be incorrect w/o the books handy.
Old Mar 23, 2012 | 03:27 PM
Javi_1591's Avatar
I had a 94 and it would tell me check gages when it had a problem but this one doesn't so I'm thinking it's just something small like spark plugs or oil change wish I had the owners manual
Old Mar 23, 2012 | 05:02 PM
Dave89IROC's Avatar
Service engine soon and check.engine are the same
Not to be confused with service vehicle soon, which is what would light for an oil change unless there is a specific change oil soon light
Old Mar 23, 2012 | 08:03 PM
The "Check Gages" light comes on when there is a problem indicated by one of the dash gages, at least according to the 2001 Camaro Owner's Manual.
The functions of the following are clearly explained in the Owner's Manual:
-Check Gages
-Service Engine Soon (US) = Check Engine (Canada)
-Oil Change
-Service Vehicle
-Reduced Engine Power
If you don't have an Owner's Manual for your car, Shoebox has a link to the online copies:
1993-2002 F-body Owner's Manuals
Old Mar 23, 2012 | 08:14 PM
Javi_1591's Avatar
thanks i didnt have an owners manual and that helped a lot
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
