Serpetine belt length for 1994 Z-28
Old Mar 28, 2012 | 05:13 PM
mitchd's Avatar
I'm going to by-pass my air due to problems with the compressor and was told all I need is the correct length for the belt without putting it around the ac and wondered if anyone else has done this and if so does anyone know the correct length or the right belt number I would need??? Thanks in advance!!!!
Old Mar 28, 2012 | 08:46 PM
Dave89IROC's Avatar
No go, you need to pull the compressor and run a bypass pulley in its location
Old Mar 28, 2012 | 10:04 PM
mitchd's Avatar
Re: Serpetine belt length for 1994 Z-28
Okay the guy at Advance Auto part's said all I needed to do was take a string and measure with going around the AC compressor, thanks for letting me know!!! The car when I bought it was making a noise and I thought it was the belt tensioner or a idler pulley till I check it out last weekend and the front of the clutch face that is pressed in came apart and is making the noise!!! If I have to pull the compressor to do that then I will just put it back on. I just not sure how that all comes out??? Not much room and it looks like it would have to come out from the bottom???
Old Mar 30, 2012 | 09:48 AM
Not exactly an "Advanced Tech" topic.... let's move this where it belongs.
Old Mar 30, 2012 | 05:50 PM
mitchd's Avatar
Lightbulb Re: Serpetine belt length for 1994 Z-28
Sorry new at this and wasn't sure where to post it so I thought I would get the most response there!!! Now I see where it should of been posted and thanks!!!
Old Mar 31, 2012 | 08:25 AM
mab6680's Avatar
serpetine belts are not measured like the old style v belts you may get lucky and find one with the string measure method but your best bet would be to get a bypass pully there cheap and you keep the factory size belt
Old Mar 31, 2012 | 09:57 PM
When you install an a/c delete pulley, you use the same belt in most cases.
Old Oct 23, 2012 | 06:54 PM
crankshaft23's Avatar
if you bypass the ac pulley your belt tensioner won't be able to work like it needs to. it kinda needs that downward pull to the tensioner so it can work right. like everyone has been saying, use a bypass pulley to get the fix you need without the price of a new ac.
POLOVETTE 94
Aug 21, 2015 07:11 PM
john henry
Aug 14, 2015 08:33 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Jocofire1
Aug 7, 2015 03:16 PM
