Security problem?
Old Oct 11, 2007 | 11:42 AM
LTgun_94's Avatar
Security problem?
94 z28. I havent started it in months, i went to start it today and i get nothing. I turn the key over and none of the dash lights come on i.e. low trac, security, and such. All i get is a binging sound coming from the steering wheel/guage area. Is this a security problem or just a really dead battery?
Old Oct 11, 2007 | 12:03 PM
2001NBMZ28's Avatar
I'd check the battery voltage first.
Old Oct 11, 2007 | 12:11 PM
LTgun_94's Avatar
Will do. But just thought id get some options first. Im going to have it tested here in a bit but the binging noise is what is getting me since i have had dead batteries before in this car and never have i heard that sound from that area.
Old Oct 11, 2007 | 02:19 PM
What did the volt meter on the dash read when you turned the key to "on"? What did it read when you turned the key to "start"?
Old Oct 11, 2007 | 10:25 PM
LTgun_94's Avatar
Nothing at all! I got it tested and it was dead, gonna try a new one tomorrow.
Old Oct 13, 2007 | 10:24 AM
HBHRacing's Avatar
Security system isn't the issue if you have no dash/gauge lights. The car will function normally with a security fault with the exception of a flashing security light.
Check available battery voltage to make sure you have any. After that you can start looking at available voltage at specific fuses which will tell you if the IGN switch is sending correct power through to the system.
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
