"security" light comes on intermittently while driveing...
Old Sep 29, 2006 | 10:32 PM
wrd1972's Avatar
What the subject says.
While driving the security light will come on then go off.
Old Sep 30, 2006 | 02:15 PM
OBE1 95Z28's Avatar
Re: "security" light comes on intermittently while driveing...
Most likely the contacts on your ignition switch that sense the security resistor on your ignition key are going bad. Common problem. You'll need to replace your ignition switch.
From Shoebox's site:
http://shbox.com/ignsw/ign_switch_repl.html
Old Sep 30, 2006 | 02:22 PM
I think OBE1 95Z28 might have gotten confused. The contacts are in the key cylinder, not the ignition switch.
Old Oct 2, 2006 | 11:16 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I work at Autozone and you wouldn't believe how many times people confuse the two or think they are the same thing... So annoying! lol
Old Oct 2, 2006 | 01:08 PM
Before they started putting the switches on the steering column, the key cylinder was integrated with the ignition switch.
Before that, the starter button was sometimes on the floor, next to the gas pedal. Even before that, you had to get out and crank it with a lever.... (not old enough to have used that one )
Old Oct 4, 2006 | 01:26 AM
Sturzkampfflugzeug's Avatar
mmm.... my '67 RS/SS has dash mounted, discrete key cylinder/ ignition switch.
dluna333
15
Mar 13, 2015 12:30 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Injuneer
Dec 15, 2014 09:36 AM
rod442
Aug 26, 2002 01:22 PM
