saggy door
Re: saggy door
Probably just need new door pins
. I'm pretty sure you can replace just the pins, and not the entire hinge
. I know you can on trucks, and the hinges on our cars look much the same. Can't be all that expensive either way though?
Re: saggy door
Glue?!
While that would explain some severe sagging
, NO, they're bolted on
. 3 bolts into the door post/frame, and I believe 3 into the door itself
. They don't exactly look "easy" to get to, but what else is new when you're talking about working on/around a 4th-gen?
Just take your time when lining up the door again ... try to get all the lines as straight and even as you can
Re: saggy door
yeah, bolt in. I was actually thinking about loosening mine up, and tilting them up slightly to take the sag out for now... I know, ghetto, but hey buying new hinges does not make me go faster... its funny, I half *** everything except to when it comes to motor/trans/rear/tires...
Gotta have priorities!
Good luck man!
Good luck man!
Aaront810
Aug 29, 2020 09:34 PM
RUENUF
Mar 13, 2016 03:37 PM
z28cam1993
Sep 9, 2015 04:08 AM
