Safe to remove tunnel brace?
I don't have subframe connectors or anything yet. I plan to go true duals with my LT's when I get around to installing them(hopefully soon). Anyway is it safe to remove the tunnel brace so I can have some extra clearance when installing the pipes? The car has been converted to T-tops if that makes a difference. Thanks.
Ever seen a car pole vault from snapping the front u-joint from all the tourqe our cars put out ? I did along time ago at a local dragstrip, wasn't pretty..if your gonna take it off I highly recomend a driveshaft catch ! or stop doing hole shots..like thats gonna happen...LOL
After installing my exhaust I put it back on but I put a few washers under each bolt so the brace sits a bit lower and clears the exhaust clamp.
Only time mine came in handy was when I ran over a truck tire re-tread and it scuffed up the underbody of the car, IMO without the brace to protect that first clamp I may have lost my exhaust.
10-31-2016 11:09 AM
Caps94ZODG
10
09-09-2002 12:08 AM
