Royal Purple
Old May 14, 2007 | 03:45 PM
THE_RUCKUS's Avatar
Royal Purple
Any positive / negative experiences? I'm debating doing my next oil change with some RP when i get her back from the shop.
For now I'll roll out in my awesome G6 lolol
Old May 14, 2007 | 04:03 PM
sscott's Avatar
I've been using it for two years now and swear it's given my SS more HP.
Old May 14, 2007 | 05:26 PM
oneclean97z's Avatar
horsepower tv has a episode where they tested it on a 2002 camaro ss and it added i think 9 horsepower to the wheels. they did change the oil, trans, and differential fluid with royal purple fluids but its no lie
Old May 14, 2007 | 05:29 PM
2000GTP's Avatar
Is your car a daily driver? If so, Royal Purple may be a little pricey to use, especially if it doesn't provide much benefit over a Mobil 1 synthetic.
Old May 14, 2007 | 07:57 PM
teke184's Avatar
"but its no lie"
since when is everything you see on TV....particularly Horsepower TV....gospel truth.
you don't suppose they show slightly exagerated gains because their show is payed for by sponsors.
hmmm
and they found gains, but what they didn't tell you was how many miles were on the old fluids. how do you know you couldn't get almost the same results by just changing the fluids to a more economical brand?
if they wanted to prove anything they would have changed the fluid to conventional or a competitors fluid and tested it. then swapped in the RP...
but i'm sure they still would have yielded a gain....it's all advertising.
REMEMBER they reccomend using a hypercrap hand held to tune your car!!!
Old May 14, 2007 | 09:53 PM
CamaroRacing12's Avatar
its def good stuff, obviously everything is exaggerated to sell...but IMO its the best oil u can buy. only around $7 a quart.... 6 quarts $42 not to bad if u do it urself
Old May 14, 2007 | 10:59 PM
F8T LT1's Avatar
I think AMS oil is the best
http://www.amsoil.com/storefront/def...spx?zo=1436102
Old May 15, 2007 | 12:21 AM
THE_RUCKUS's Avatar
my buddy works for a distributor and I BELIEVE I may be able to get it for cost.
If so, is everybody down to pitch in and get a pallet? haha
My Z has merely 13,000 on it. I BARELY treat it like a daily driver in the summertime. NEVER in winter. It's a car. It's meant to be driven. Too many people overlook that.
Old May 15, 2007 | 08:03 AM
teke184's Avatar
i'll stick to Mobile 1
never let me down...
Old May 15, 2007 | 08:07 AM
rskrause's Avatar
Moderator
Waste of $$$.
Rich
Old May 15, 2007 | 08:47 AM
Rice Killer87's Avatar
I run it in my sled and I hot lap the **** out of it and NEVER had a problem.
We also have a 50 foot houseboat w/ twin 454's in it and we switched to RP in both motors and picked up 3-5 GPH (Gallons Per Hour) over any other oil we tried. So I guess your right,it doesnt work .
Old May 15, 2007 | 08:53 AM
rskrause's Avatar
Moderator
I'm sure it works fine, it is a waste of $$$ as many cheaper oils work just as fine. It's your money and my opinion.
Rich
Old May 15, 2007 | 09:29 AM
U240's Avatar
I just switched to rp from mobile1 and i am getting almost 30 miles more per tank of gas.I was a big mobile 1 fan had never used anything else until now dont know why i tried rp but it seems to be working good
Old May 15, 2007 | 09:52 AM
Greed4Speed's Avatar
I've seen my car and many others pick up 5-10 hp between dyno pulls. This is with NO changes.
Old May 15, 2007 | 11:23 AM
moparman's Avatar
I saw Royal Purple at PepBoys. $6.19 per qt.
