rough start help
i have a small problem with my car dunno what it is but when im at a stop it idles a little rought n then when i let of the brake and tap the gas it has a little rought take off like it kind of hesitates when i push the gas but after that it drives smooth what can it be its a 02 z28 but i just replaced the wires and plugs so i know its not that
k i had it checked out at first after its been sitting if i put it in the on position it read a lil under 20psi n when i started it it read a lil under 60 the second time i tried it i let it run for a lil n it read 50 on the on position n 60 after i turned it on
i also checked the obdII n i have a bad o2 code n its been there before and after i installed the header and ory
so im thinking about gettin new o2 sensors and maf what do yall think could that be causing my stumbling
