Reverse lights not getting signal from transmission
Old Aug 4, 2013 | 10:37 AM
canbaufo's Avatar
Angry Reverse lights not getting signal from transmission
...that appears to be the culprit of the problem. I posted this in the electronics forum but it's a REALLY slow forum. Anyway I'm quite sure that the problem is related to a sensor or wire coming from the trans, that's the long and short of it ...but I don't yet know how to fix that. If anyone cares to read about everything I've tried in detail (about 10 hours deep now) here's the post from the other forum, but I don't think there's any need to read all that:
https://www.camaroz28.com/forums/car...please-875155/
Just thought I'd walk away from it for awhile and try to get some help before putting more hours into searches. Thanks in advance to anyone that has time.
Old Aug 4, 2013 | 12:05 PM
Re: Reverse lights not getting signal from transmission
The backup light switch (not a sensor) is on the passenger side of the trans. It's the only electrical connection on that side. It's either a faulty switch or a loose wire.
Key on, you should have 12V on the brown wire at the switch harness connector (measure with a volt meter from the brown wire pin to ground on chassis).
With the connector on the switch, in any gear other than reverse, you should have 0V on the light green wire in the harness connector. When you shift it into reverse, you should see 12V on the light green wire.
Old Aug 5, 2013 | 12:02 PM
canbaufo's Avatar
Thanks a bunch! I'll try that out and see how it goes.
Old Aug 26, 2013 | 09:01 AM
canbaufo's Avatar
That (switch) was THE fix, thanks!
Old Aug 26, 2013 | 01:36 PM
Laymaster's Avatar
Where did you get the switch from and how much did it set ya back? I think I have the same issue.
Old Aug 27, 2013 | 08:20 AM
canbaufo's Avatar
Advanced had one for $11 ....I was shocked and pleasantly surprised.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
