reverse lights
Old Aug 22, 2004 | 07:47 PM
97Transam123's Avatar
reverse lights
I searched and couldnt find anyone with the same problem..
I have a 1997 Trans am with a 6 speed
My reverse lights wont turn on when i go into reverse.
I have the hole back taillights off the car and bulbs look all good. could it be a switch near the shifter for the reverse lights? or how does that work? thanks\
Old Aug 22, 2004 | 08:06 PM
Re: reverse lights
The B/U light switch is mounted into the passenger side of the tranny, high up, toward the front.
Old Aug 22, 2004 | 08:27 PM
Re: reverse lights
does this go bad alot? or is it just me? and when u say high up like stick ur hadn into the dash and reach in there? with the shift *** and boot all off? or is it gata be loactaed from underneatH?
Old Aug 22, 2004 | 09:55 PM
LT-14me's Avatar
Re: reverse lights
I did a post about this in the ls1 section a while ago, and it has happened to me, my reverse lights just died...i was told it was because of the switch. Replace the switch and the lights will work. I am just too lazy to do it
Old Aug 22, 2004 | 10:11 PM
Re: reverse lights
The switch is on the side of the tranny, toward the front, about 6" behind the bell housing. The shifter is at the very back of the tranny.... so they are nowhere near each other. You need to go under the car to get at it. All you will see is a plastic harness connector/plug, and a hex about 3/4" that is used to screw it into and out of the tranny case.
Old Aug 22, 2004 | 11:59 PM
Re: reverse lights
ok ill try that tomorrow thanks for the replies
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
kizz
Aug 28, 2002 09:39 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
