Replacing Serpentine Belt Tensioner
Old May 11, 2011 | 09:51 PM
Bop's Avatar
Bop
Post Replacing Serpentine Belt Tensioner
I had the mounting brackets for Alt, PS, AC from my 89 Camaro powder coated and the quy doing the work removed the belt tensioner from the bracket. It is spring loaded and I need some help (instructions) on how to reinstall it and set the proper spring tension. Will I need any special tools?
Thanks,
Larry Barbare aka "Bop"
Old May 12, 2011 | 08:28 AM
rv93's Avatar
Re: Replacing Serpentine Belt Tensioner
assuming its the same as in the 4th gen, it will only fit one way. you bolt it in, then get the belt mostly in the right place, use a wrench to compress the tensioner spring, put the belt over it, and let go.
grabbem88
Feb 23, 2015 09:41 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
94_Z28_ragtop
Sep 12, 2002 12:09 PM
