Replacing power window motor
Old Oct 31, 2015 | 07:21 PM
kozmosis's Avatar
I have read the instructions by Shoebox on how to replace the motor, but I still have a few questions. I am assuming the window must be up to perform the necessary tasks. My window is currently down, will it manually go up once I have access to it? Although it is not mentioned, I should grease the regulator while I have access to it, using some lithium grease? Any other items I should know? First time attempting this.
Side note. Just got my car back after having a new Strange S60 Rear put in, had about 450 miles on the new rear and was going to have the fluid changed when the window stopped working. But I love the new rear.
Old Oct 31, 2015 | 08:50 PM
JakeRobb's Avatar
Super Moderator
Re: Replacing power window motor
You should be able to lift the window glass by hand once the door is opened up.
I'm jealous of your S60. That's on my wish list.
Old Nov 2, 2015 | 08:29 AM
Originally Posted by shbox.com window motor instructions
Remember that the window motor must overcome any mechanical resistance in the window regulator mechanism (that scissors looking thing ;-) ), so it is a good idea to make sure the guides are clean and well lubricated (lithium or silicone grease will do fine). Also inspect for any broken or loose rollers.
This includes anything else you want to grease. Lots of first timers have used the instructions with success. The window being up keeps it out of harms way and gives you more room to work.
KYWes
May 7, 2015 08:12 AM
timmy39120
May 2, 2015 05:12 PM
Fatdog2
Jan 24, 2015 12:08 AM
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
regular Joe
Aug 10, 2002 07:15 PM
