Replaced Trans, No power steering
Old Jul 10, 2006 | 10:27 PM
19z28camaro02's Avatar
wtf
Old Jul 10, 2006 | 10:34 PM
OBE1 95Z28's Avatar
Re: Replaced Trans, No power steering
Did you spill tranny fluid on the accessory belt that would cause it to slip?
Old Jul 11, 2006 | 04:24 PM
95LT1Z28's Avatar
Make sure the belt is routed correctly and spinning the pulling, check your power steering fluid, make sure fluid is not on the belt causing it to slip, and if that isn't it make sure all your lines are connected and not leaking. If none of the above is the problem you probably have a faulty PS pump.
Jeff
HectorM52
Jul 30, 2017 11:46 AM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
SLIMJIM
Jan 7, 2003 11:06 AM
Paulberg
Jul 26, 2002 11:35 AM
