Replaced Trans, No power steering
Re: Replaced Trans, No power steering
Make sure the belt is routed correctly and spinning the pulling, check your power steering fluid, make sure fluid is not on the belt causing it to slip, and if that isn't it make sure all your lines are connected and not leaking. If none of the above is the problem you probably have a faulty PS pump.
Jeff
Jeff
Hurin
Dec 13, 2014 07:38 PM
