Removing Traction control
Old Jul 10, 2004 | 12:04 AM
  #31
Robert_K's Avatar
How exactly does the ABS feature work? I know is stops your car from skiddding when the brake is pushed to hard, but how exactly does it do this?
Old Jul 10, 2004 | 07:05 AM
  #32
biobob's Avatar
Thumbs up
when you disconnect the traction control adjuster motor the ecbm fails its diagnostic that occurs when you start the car. it thinks that the adjuster motor has an open circuit and disables just traction control. the light "traction off" lights on the dash and traction control only is disabled. abs and cruise are not affected. it is really easy to test by unplugging the adjuster motor connector and starting the car. i did mine months ago. once i was satisfied that it worked and my abs and cruise were fine i ordered
non traction cables from dal and removed the adjuster motor entirely. my engine looks better and i was able to use a regular stb with no problem. i did some hard stops on gravel to make sure abs worked and i tried the cruise, both ok.
bob
64 vette
95 trans am vert m6
94 impala ss
94 lt1 caprice
Old Jul 10, 2004 | 10:09 AM
  #33
WhtLT1's Avatar
Ok so wat cables are ACTUALLY involved in converting from traction to non-traction? I ordered a non traction throttle cable today is that all I need? Wat else is needed?
Old Jul 10, 2004 | 10:51 AM
  #34
SantaCruz163's Avatar
Well I just unplugged the wires going to the TCS motor and started the car up. I didn't get the ABS light on which is good. I didn't have the TCS light come on but thats alright because most of the time when I just turn it off with the switch it doesn't light up on the dash, but the LED light on the switch didn't light up=TCS is off. So is this it to disabling TCS while keeping ABS, have we cracked the mystery?! I really hope thats it. If so I'll be ripping that FUGLY motor out ASAP!
Old Jul 10, 2004 | 06:59 PM
  #35
Robert_K's Avatar
Where exactly is the TCS motor located?
Old Jul 10, 2004 | 07:40 PM
  #36
Jeffs94Z28's Avatar
buy a link for a laptop to your obdii and disable traction control with that. Well I think it would...I have a 94 so its all good.
Old Jul 10, 2004 | 07:53 PM
  #37
Well you obviously don't have TCS because you would be staring at it everytime you open your hood and just think about how ugly it makes the engine bay. It's located on the drivers side valve cover.
Old Jul 11, 2004 | 01:02 AM
  #38
Robert_K's Avatar
Do the 93-94 models come equiped with the TCS? Or is it an option?
Old Jul 11, 2004 | 09:07 AM
  #39
biobob's Avatar
if you have traction control there is a large black plastic lump of crap above the middle of the drivers side valve cover. the throttle and cruise control cables attach to to it. i will post the part numbers for the non traction throttle cable and cruise cable tommorow. to complete the removal the throttle and cruise cables should be replaced with non traction ones, not a difficult job, took me about 45 minutes.
bob
64 vette
95 trans am vert m6
94 impala ss
94 lt1 caprice
Old Jul 11, 2004 | 12:17 PM
  #40
Robert_K's Avatar
do i need the other 2 cables? They make my throttle hard to open, and to go WOT, I have to really press hard. Can I just run the throttle cable? What are the adverse affects. BTW I never use the cruise control, EVER!
Old Jul 11, 2004 | 02:55 PM
  #41
CamaroBoy96Z28's Avatar
You can run just the throttle cable.
Old Jul 11, 2004 | 11:05 PM
  #42
Robert_K's Avatar
Will there be any problems with just the throttle cable? I know one of the others is for keeping the car up to speed, but what is the other one for?
Old Jul 13, 2004 | 09:53 AM
  #43
biobob's Avatar
cable part numbers
the non traction throttle cable is partnumber 12550676 and the cruise cable is 12550719
Bob
64 vette
95 trans am vert m6
94 impala ss
94 lt1 caprice
Old Jul 13, 2004 | 12:25 PM
  #44
Just something to add....I've noticed that basically everyone who has posted in this thread is OBDI except me. Must be an OBDI thing because my ABS doesnt work (ABS INOP light) when I unplug the ASR motor as I already knew, but had to try it anyway. I was hoping to be able to sell my non-ASR EBCM and just throw the cables in, but I guess not. OBDI is so much more leniant with removing stuff.
Old Jul 13, 2004 | 02:28 PM
  #45
WhtLT1's Avatar
Ya mine did the same thing in my 96 I just dont' car, my dash is like a freakin light show, i have my ses light, my abs, my asr, my low oil, adn my air bag light haha
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
