Removing Traction control
Ok so I'm lookin into removing it one, cause it clutters the engine bay adn two it's just a general pain in the a**. So wat is all involved? Wat am I goin to need to buy and remove to make the car work without it? Are there any writeups anywhere on it?
No one I know of has a write-up. Are you looking to just remove ASR or do you want to keep ABS too? I dont think anyone has any idea about removing ASR and retaining ABS because very few if any reply to these threads. After doing my own research after asking many times, it looks fairly straightforward and I plan to do this at the very latest over the winter. For just removing it, get a non traction control thorttle and cruise cable and throw those in. Get traction control programmed out of the computer and you're done.
just disconnect the 2 wire plug to the tcs adjustor motor (under the black cover over the intake manifold). This causes a dtc 164 error on the ecbm and disables traction control. no effect on abs or cruise. no main pcm errors. if you like you can remove the adjustor motor and replace the throttle and cruise cables with non traction ones. a few seconds after the car is started the tcs light comes on and its disabled.
Bob
Bob
I dont think its that easy. Otherwise, it would be done quite often. Ive seen people go through all the trouble of buying new ebcm's and other stuff, and still not retain ABS when TCS was removed. However, my question is this. Is there a way to simply relocate the box? Like, to the firewall or something? Cuz I know you need to relocate it or remove it for some Superchargers, so maybe there is a way. It seems like it wouldnt be that hard, but that doesnt mean that I know how to do it! LOL!
It is very simple to turn it off and have it stay off....
Traction Control Logic Module
If you’re one of the owners of a fourth-generation Camaro or Firebird equipped with traction control, you know how much of a pain it can be to forget it’s activated when you’re at the track, getting ready to make a pass or execute a burnout. You’re immediately met with a stall on the starting line or in the burn-out box when you dump the clutch in a 6-speed car, or bogging from an automatic equipped car. GM has designed your car's traction control system to activate as soon as you start the car, but sometimes it's just not necessary. SLP has come up with a new little device that actually reverses the activation of your car's TCS function, by not having the system activate until you turn the manual switch on located on your car’s dash or console. No more embarrassing or annoying moments at the track. Installation couldn’t be easier, since this device is a simple plug-in.
Add to:
Part # Product Price My Cart Wish List
28-63014 SLP Traction Control Logic Module, 1997-1998 F-body $49.95 Buy Wish
http://www.thunderracing.com/catalog...vid=4&pcid=156
Add to:
Yeah, that works, but for 90% of the people, the reason they dont want it, is because of that huge ugly box in the engine bay, not because they forget to turn it off once in while. Personally, I would love to just relocate it, but removing it, while retaining ABS would work also. It just sucks that its so hard to do.
