removing steering wheel lock
Old Sep 19, 2008 | 05:00 PM
tom3's Avatar
Question removing steering wheel lock
if you look at the picture on shoebox's site:
http://shbox.com/1/steering_column_exploded.jpg
the item number 6 (lock, shaft) is where I am stuck at
What kind of tool to use?
I tried to pry it off with absolutely no success
Old Sep 20, 2008 | 03:37 PM
tom3's Avatar
I tried to borrow a puller but I can not fit it in there.
Any idea?
Old Sep 20, 2008 | 04:22 PM
You have to use a compressor to push the lock plate in, so that you can remove the snap ring. It's a very simple and cheap tool you can buy/rent at most auto parts stores.
Old Sep 20, 2008 | 04:56 PM
tom3's Avatar
yes, I have done that, but I am stuck on the next step:
The wheel with the notches that is used to lock the steering wheel. I can not get it to move even a little bit.
Old Sep 20, 2008 | 05:19 PM
Green96Z's Avatar
That's what Shoebox is telling you. You need a tool like this:
http://www.grainger.com/Grainger/ite...0Lock%20Plates
You thread it onto the steering wheel shaft, and it compresses the ring down. Then you remove the C clip (number 5) and the ring comes off.
Old Sep 20, 2008 | 06:42 PM
tom3's Avatar
ahhh! I realized I didn't think right:
I had removed a clip with the lock plate compressor, I didn't think there was two!
ok, this is now done!
I am trying to find out why the key is very hard and needs to be forced; I removed the ignition switch, so it is not the problem.
I now finally removed the key cylinder and it works smoothly.
so it has to be something in the mechanism in between...
do you know what size torx screws are there? I see three and I don't have a bit that fits them
Old Sep 20, 2008 | 07:57 PM
Green96Z's Avatar
I'm not sure what size they are, but when you get that housing off you can take a closer look at the sector gear. The metal shaft that the lock cylinder turns goes through the lower housing across to a vinyl gear (sector gear) and you may very well have sheared some teeth off of that.
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
