Removing EGR studs in the intake?
Old Jan 15, 2010 | 07:23 AM
blackbirdta's Avatar
So when using EGR block off plates how do you take out the studs in order to use nice stainless screws? There is a star looking head on them, but I am not familiar with a tool like that to remove them. I have seen the star screws, much like an allen head, but never a socket like tool that it looks like I need for this. Thanks!
Old Jan 15, 2010 | 07:30 AM
That would be a torx head. You need the proper size torx socket. Or you could probably double-nut them to pull them out.
Old Jan 15, 2010 | 07:54 AM
right, torx was the word I was looking for but all I could come up with was star . I guess I knew what I needed then, I've just never heard of a torx socket . Could you explain how I can "double-nut" them? thanks!
Old Jan 15, 2010 | 09:46 AM
Z28SORR's Avatar
Your kidding right??
Thread two nuts onto the stud. Tighten them against each other, i.e. tighten the top one while loosening the bottom one, until they are very tight. Then using the bottom nut, attempt to loosen it, that should unscrew the stud. If the nuts move tighten them against each other harder.
or you could get a stud removal tool from the auto parts store.
Old Jan 15, 2010 | 12:20 PM
If I was kidding do you think I would have asked . At least you followed it up with help though..thanks
Old Jan 15, 2010 | 05:17 PM
LOL, he asked about kidding because double-nutting is pretty much the standard way you install/remove a stud.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
97SSdude
Dec 31, 2014 07:43 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
