Removing EGR studs in the intake?
So when using EGR block off plates how do you take out the studs in order to use nice stainless screws? There is a star looking head on them, but I am not familiar with a tool like that to remove them. I have seen the star screws, much like an allen head, but never a socket like tool that it looks like I need for this. Thanks!
right, torx was the word I was looking for but all I could come up with was star
. I guess I knew what I needed then, I've just never heard of a torx socket
. Could you explain how I can "double-nut" them? thanks!
Thread two nuts onto the stud. Tighten them against each other, i.e. tighten the top one while loosening the bottom one, until they are very tight. Then using the bottom nut, attempt to loosen it, that should unscrew the stud. If the nuts move tighten them against each other harder.
or you could get a stud removal tool from the auto parts store.
Your kidding right??
. At least you followed it up with help though..thanks
Jul 4, 2005 05:00 PM
